Posted by FBH44 on June 10, 2013 at 03:53:15 from (64.85.217.212):
In Reply to: H running rich posted by HenryO on June 09, 2013 at 15:28:58:
Jim is correct, here"s my complete "H" carb tuning procedure;
Make sure the float isn’t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so it doesn’t rub or touch. Pretty important. Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber. Initial settings are as follows to get it started; Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture. Idle fuel-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner. Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages the slot. Final settings are determined as follows; Get the engine warmed up, and idling. Turn OUT the idle fuel-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.) Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine sits at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.) Should rev up smoothly and evenly. Too Lean = stumble, sputter, damaged melted plugs. Correct = tan plugs. Too Rich = back smoke, black sooty plugs.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
