Re: Farmall H shifter problem
Posted by Janicholson on June 15, 2013 at 19:34:28 from (74.60.94.18):
In Reply to: Farmall H shifter problem posted by Ernie Overton on June 15, 2013 at 16:09:17:
If the shifter feels normal, and has the Double "H" pattern, and is sloppy but feels like there are gears it is moving, the issue could be a sheared constant mesh gear Key on the countershaft. If sheared, the gear will turn free, but not drive the output. It should work in 5th (try that to see if it will pull the engine down as normal. If it does not, there is some other issue. It could be a broken final drive, or differential gear.
One way to see if it is in the final drive (after the trans) stepping on the brakes when the clutch is out will slow the engine (4th gear). Jim
Take off the belt pulley and look to see if gears are turning.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
