Re: H Coil Blazing Hot and Other Wiring Questions
Posted by Bob M on November 22, 2000 at 05:16:17 from (192.232.120.194):
In Reply to: H Coil Blazing Hot and Other Wiring Questions posted by Aaron on November 21, 2000 at 19:33:22:
Aaron - Your description indicates the generator isn't wired right. Punch the link below - it'll take you to a wiring diagram for a setup with a 4-terminal regulator like you've got. Note: If you've got a 4 position "LHDB" light switch you're gonna wind up with an unused resistor terminal on the light switch when you're finished. This is because the original setup had a cutout relay only (no regulator). Voltage regulation was manually controlled by the light switch/resistor combination. The hot coil problem however is puzzling. My experience has been 6 volt coils work fine and run cool without additional resistors on 8 volt systems. A couple of possibilities: 1 - The coil is defective (got an internal short). Does the tractor start/run with this coil? 2 - You simply left the ignition switch "on" for an extended period with the motor not running. This can overheat the coil - may also burn the points too. Hope this helps... Bob M PS - ltf is right - if the tractor is positive grounded, the + on the coil should go to the distributor and the - to the ign switch, as shown on my diagram. Bob M
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
