Loose is not acceptable. They are usually an interference fit of great difficulty to remove (I have seen 20 ton applied before it gave up a millimeter. If it was a locational fit that was just movable on the shaft, I would drill and tap for a set screw, then grind a flat on the crank, or drill a divot in the crank to accept the crown of a crown point set screw. If loose, a different pulley is best. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
