HI,you can change the brake band with the cab in place. Remove the fuel tank, seat and seat plate, remove all the hydrolic pipe and all the bolts. Normally, with a helper, you can remove the hitch cover by hand, one in the cab and another in the rear of the tractor.. With a car engine hoist, it work fine. Make sure to lift the cover enough, it have a spring under for the draft control You have to remove the PTO clutch pack, to slide the band out, dont pull or twist. Change the gasket and the 3 teflon ring, maybe Oring also. Bernard le mecano Quebec Canada
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
