Hard starting problems can be several things . (1) your pump and injectors may need rebuilt . (2) the valves may need to be readjusted (MAY) (3) it may need a valve job as if the valves are setting down in the head to far then this will reduce cranking compression. (4) your sleeves and pistons maybe plum slap wore out and you are low on cranking pressure . You have no idea when or IF it was ever overhauled . So you maybe looking a a total rebuild and if you have to go that route then install the updated pistons and make sure the machine shop knows how to get the valves as there proper height. and do the fuel system at the same time . If it has been started with EITHER SHE GO OR EITHER SHE BLOW then i am betting on the total rebuild .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
