Sorry, I did not post anything yet. I have only had one haying window this season, around the 19-22 of June. I cut one field and got 294 bales, used my new $200 NH 68 baler after I put on a tire and chain and made new plunger bearings for the bottom. The 300 was great, I was able to run the 9' haybine in 2nd gear and used the TA a little bit while climbing some of the steeper hills. I would have had enough power to run in 3rd but I did not steer as well, especially on the corners. The temp never got over about 150 or so on the gauge, the oil pressure stayed past the halfway point even when hot and everything went well except that I had to bale the last 60 bales with the Massey 35 because the 300 stopped getting gas to the carb. I took it apart and found that rust flecks had built up in the sediment bowl inlet because I was only opening the valve about 1/2 turn and there was not enough room for them to be flushed down into the bowl. Now I open it two full turns and that should be far enough to keep that from happening again. I do not know about the fuel economy, I do not keep very good track of how much gas I use. I just peer into the tank and if it looks low I put in some more. Overall I am very happy with the 300 and I especially liked having the fast hitch so I did not have to jack the baler and haybine tongues up, and having the springy seat with a cushion on it. The governor response also seemed a lot smoother than on my H, the engine speed was much more constant without my having to do anything when I went from uphill to downhill. Zach
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
