There are 5 places where the system can be worn. In the bearing at the end of the shaft going into the box. This ball bearing is responsible for holding the shaft on its axis. When rotating the steering wheel (that 1/4 turn) the shaft must not move in and out of the box at all. Put a mark on it to see if it is that bearing then turn the wheel. The mark should go around not in and out as it goes around. The bearing cap nust be tight to assure this is correct. The worm and sector gears can be worn. If they are there will be play no matter what else happens. New or good used gears are required to fix it. The sector gear can be loose on its shaft. Key way I think. The sector shaft can be loose in its upper and lower bushings. New bushings and possible new shaft to get clearance at .0015 to .001" if possible. The steering arm can be loose on the sector shaft. Some have a woodruff key, some are a tapered square shaft. Remaking the key pocket, and the arm slot to fit a larger key is a good fix. Ball joints and tierods need to be looked at, but I assume it is not that. I hope this helps. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
