Re: Replacing Super A PTO bearings
Posted by TractormanNC on July 08, 2013 at 17:23:55 from (108.72.58.200):
In Reply to: Replacing Super A PTO bearings posted by Gerry Powell on July 08, 2013 at 16:32:15:
You need a THREE jaw puller in the holes of the gear to remove it. Remove gear,and woodruff key and the shaft will press out toward the REAR. You can't press the shaft out without removing the key as it will hang up on the bearing.
Looks like your shaft is grooved also. Get a speedy sleeve for it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
