rhtx55 said: (quoted from post at 03:56:30 07/08/13) There are two gaskets for the tower also, one at the top that the steering shaft housing bolts to, one below that where the tower attaches to the reservoir. I used the red anaerobic sealer available at Case IH on these two gaskets and no seepage at all.
A parts diagram will show you what orings go where,
(there are a bunch of them) be sure to have your parts man give you an estimate sheet, this will give you the original part number and what new part number replaced it.
The numbers have changed several times over the years, that way you can use your parts book to see which orings go where.
I gently used a mill file on each flat surface to ensure there would be no gaps caused by old paint or rust, and used emery cloth to clean each oring mounting surface of any debris. When I assembled them I used a small amount of wheel bearing grease to hold the orings in place during assembly.
I will try the Emory cloth on the seats, that's the only thing I didn't do last time.
This post was edited by Bkpigs at 19:05:53 07/08/13.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
