1486 Hyd problems. Where's the releif valve?
Posted by Larry B. 1486 on July 09, 2013 at 17:58:55 from (98.19.163.140):
Have some hyd problems on my 1486. I only have 1,800 psi on the external outlets. I have changed relief valves on 706 thru my 1466 that screw in on the right side of the lift cover but never on a 86 series with a cab. Do they use the same relief valve as the 06,56 and 66 series tractors? Is it located in the same location as well? A few years back when I checked it, it was putting out 2.400 psi. It struggles now to pick up the bat wing bush hog. The filter is good and oil level over the full mark. Though I would start with the valve before I pull the pump. Thanks for any help.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
