How to tell if a tractor is positive or negative ground?
Posted by Brad in WI on July 10, 2013 at 19:22:07 from (50.116.142.39):
I am working on a 240 Utility for a friend of mine and we are unsure of it has a positive or negative ground electrical system. My neighbor took out the battery and did not look to see what side of the battery went to the starter. Is there some wires that I can check to make sure that when I put in the battery that I have it correct. It is a 6 volt system with a working generator. We are going to replace to wrecked battery with an 8 volt and replace the one screwed up cable. I just don't want to wreck more than what was already done. Thank you. Brad
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
