Posted by The tractor vet on July 12, 2013 at 07:28:20 from (76.212.226.124):
In Reply to: 706 cooling problem posted by daveminn on July 12, 2013 at 06:09:16:
Well here is what ya need to do to figure out what is going on , remove the thermostat housing and remove the thermostat unhook the water pump belt . This is to be done on a COLD engine fill the block with water till it is even with where the thermostat sets . Start the engine and rev it up hard , IF water comes shooting out like old faithful then HUSTON YOU have a problem with compression getting into the water system . This could indicate a leaking head gskt. a cracked head or cracked block . If nothing showes up there then i would be looking at a ing. timing issue and also what octane gas your running and maybe a lean burn condition due to a carb problem .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
