Posted by red.green on July 13, 2013 at 05:19:53 from (76.209.53.143):
In Reply to: E4A mag posted by EM Iowa on July 13, 2013 at 04:50:39:
If the problem is consistent and only I plug it not the points,
First check to see if it’s the plug and wire, Are they in good condition? Swap #3 plug and wire with another and see if the problem moves over.
Next check the distributor cap, on the inside of the cap there is a carbon that rides against the rotor is it in good condition and does it have some spring action like the others?
On the outside of the cap does the wire have a good clean connection, if not clean it with a piece of scotch brite and reconnect.
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
