Posted by Owen Aaland on July 14, 2013 at 20:51:18 from (216.47.34.191):
In Reply to: 2444 hydraulics posted by Bob2444 on July 14, 2013 at 14:15:16:
For tractors without front mounted hydraulic pump, forward and reverse, and/or continuous running power take-off, my Operator's Manual shows a plug (#24) on the right side of the rear frame housing just ahead of the pivot for the park brake lever. That is just under the platform on the right side.
Tractors without front mounted hydraulic pump but with forward and reverse drive, and/or continuous running power take-off; keep the fluid level up to the level plug opening (26). This plug is located on the left side of the clutch housing just ahead of the clutch pedal.
For tractors with front mounted pump (like mine) the correct level is six inches below the filler plug opening.
Transmission capacity is 5 gallons for tractors without front mounted hydraulic pump or draft control; 14 gallons with front mounted hydraulic pump, without draft control; 17 gallons with front mounted hydraulic pump and draft control.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
