To get a 123 up to a 135 also requires a change in crankshaft.
Standard bore for a 123 is 3.125". Oversize pistons and sleeves are 3.25, the same as the C135. However, the C135 also uses a crankshaft with a stroke of 4.0625 versus the 4.000 used in the 113 and 123 engines. Using the 3.250 pistons and the 4.00 crankshaft leaves you with a 132 engine.
There is also a C146 engine that was not used very much. It is basically a C153 block with a C135 crankshaft.
Bore and stroke for all the engines in this family are as follows:
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
