2000 loader on a F-460 will not bolt directly on to a F-350 "as is". It will require modifications to the subframe rear axle mounting method and acquiring of proper front mounting brackets. Subframe from a loader mounted on a 460 tractor may require shortening to get it proper length for a 350 tractor . A good welder with design engineering skills could make modifications to the rear subframe and could build front brackets that would work satisfactorily. Compare illustrations 11A (460 tractor) and 11E (350 tractor) in first scan for rear axle mounts. In second scan , compare Illust. 10C (460 tractor) with Illust. 10E (350 tractor) front mount brackets. Hope this helps.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
