Posted by John T on July 22, 2013 at 04:05:09 from (216.249.76.176):
In Reply to: 130 starting circuit posted by beatle on July 21, 2013 at 17:11:52:
On a Pos ground system the coils + (if wired right) connects to the distributor and its points and if you turn the ign, ON although theres is voltage over on the coils other - input, THERES "USUALLY" NO VOLTAGE ON THE COILS + AS THE POINTS ARE USUALLY CLOSED WHEN SHES JUST SITTING THERE NOT RUNNING. Sure if a piston just happens to stop at TDC on compression the points would be open, but that usually dont happen.
If you place a test lamp on the coils + to distributor terminal and turn the ign on and slowly turn the engine over, it should flash ON (when points are open) and OFF (when points are closed)
If you work through my Ignition Troubleshooting Procedure linked below it can diagnose the cause of no spark.........
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
