656 hydro rear battery box, why?
Posted by Mick29 on July 22, 2013 at 19:30:32 from (184.176.202.132):
This message is a reply to an archived post by jim fowler on March 04, 2012 at 08:22:19.
The original subject was "656 hydro rear battery box".
these IH engines are a high compression thin wall dry sleeve design, & were designed to use glow plugs all seasons;
if your glow plug meter is stuck to the right, the engine will crank until the battery is boned, white smoke, etc;
one good battery is all that is needed; summer glow plug on time is about one minute, winter on time is three to four minutes;
the thin wall dry sleeve design cannot take the combustion pressure of ether, should you use ether you may well bone your engine;
new battery cable are also preferred;
my 656D starts & runs fine all winter, Minnesota, uSA
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
