The voltage regulator your SC now says it's been converted to 12 volts. Ground polarity now could be either way, depending on the whim of whoever did the conversion. (From the factory it was 6 volt, positive ground)
A couple ways to determine polarity:
1 - Check the voltage regulator. Some (not all) VR's are designed for only one polarity. So ground polarity MAY be marked on the cover.
2 - Drop in a good battery and connect it for POSITIVE ground. Now turn on the ignition or lights. If the ammeter deflects to the left (indicating discharge) it is wired positive ground. However if it deflects to the right it is negative ground.
Once you've determined the ground polarity and completed your wiring, good practice is to polarize the generator before the 1st start: With the battery installed and the engine stopped, briefly jumper the BAT and GEN terminals at the regulator. Soon as you've made contact your generator is polarized.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
