Posted by mazemeister on July 27, 2013 at 10:24:22 from (69.127.90.15):
In Reply to: Re: IH 966 posted by notjustair on July 26, 2013 at 19:35:13:
OK let's clarify a few things here. Adding a turbo in and of itself does not add any stress to the machine. it will still only develop as much power as the load on it requires. even if you put a load on it, you only get (much) more power if you also increase fuel delivery!
No matter how much you increase the fuel, that is the max setting! the pump will only deliver the increased fuel if you put an increased load on it.
if for example you take a stock 806 that is set at 95 HP and put a turbo on, then set at 95 hp again, you will probably end up turning the pump DOWN, have cooler exh temps but still have the same torque at the flywheel at a given load.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
