SM Carb Help Please
Posted by Pete_5959 on August 04, 2013 at 05:55:04 from (70.63.206.198):
I am having some difficulty in setting the low RPM to 350-400. I initilly set load screw at 3 turns out, air adj and idle screw per service manual. I am using dwell/tack and cannot get the idle rpm below 650 without adjusting load screw to where the engine is not running smoothly. At 3 turns out starts easily but if I turn in 1/2 to 3/4 of turn engine smooths right out and rpm"s increase about 400. The idle screww is fully backed out. Could the governor being out of adjustment cause this? Thanks for any advice.
R/
Pete
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
