There are several ways to do it. One absolute is the linking of the spindles so they follow Ackerman principles. A tierod between the sides and attached to steering arms as shown in the diagram, is a good solution. If the 504 has 2 push pull drag links from a gear box, one on each side, that geometry (and the gears in the box that control the links, as well as the geometry of the arms on the box,) are responsible for the Ackerman effect. Thus if your front end has that Utility style linkage, either the gears are needed, or new fabricated steering arms on the spindles are needed with a link between them as shown in the diagram. Two different approaches are used to power the steering one type uses 2 identical single acting cylinders, each pushing in opposite directions. Sometimes they are placed on the drag links on opposite sides, sometimes attached to the center of the cross rod and anchored to the axle. Some use a single double acting cylinder that pushes and pulls on one link. Either way a bracket, or two, must be welded (with professional absolutely fail proof strength) so the cylinder/s are positioned to allow full steering movement "lock-to-Lock" Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
