Re: 6 Volt Battery Wont Turn Cub??
Posted by mkirsch on August 06, 2013 at 10:23:36 from (64.80.110.75):
In Reply to: 6 Volt Battery Wont Turn Cub?? posted by anvilheadtexas on August 06, 2013 at 08:21:47:
Even if you have super-heavy jumper cables, the clamps only have a small area of contact, just the tips of the teeth.
Usually the biggest problem is finding a good ground. Clamping on to rusty metal is usually the main cause.
Odds are the starter could probably stand to have the commutator cleaned up, new brushes, etc. regardless.
If you want to just see if you have spark, then just use the 12V for now. It won't hurt a thing to run 12V for a few minutes.
Or, hook the coil up to 6V and the starter to 12V. Just make sure to connect the same post from each battery (both +) to the tractor frame.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
