Posted by gene bender on August 07, 2013 at 09:33:24 from (67.55.226.10):
In Reply to: Super A rear main seal posted by Adrian Billheimer on August 07, 2013 at 08:35:54:
NO that seal is quite a piece of work. The flywheel will have to be removed then the seal thingy is bolted to the block and its in two pieces and uses felt for a seal they are two small pieces and are inserted into those two halves then bolted back up to the block. The felt has to be installed very careful. The small gaskets probably can only be purchased with an out of frame gasket set. If you are careful they could be used again with some thin sealer. Only time ive replaced is when i have had the crank reground but that is the procedure.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
