M waterpump brass packing gland, how tight?
Posted by Patrick HMD on August 09, 2013 at 15:41:48 from (75.0.227.170):
I just got an aftermarket waterpump. The brass nut was loose, so I'm not sure how tight it should be up against the packing itself. Any set rule on this?
On the old OEM pump, the brass nut was real tight, but seemed to be working OK with no water leaks.
The only reason I replaced it was that the shaft had very noticeable end play. Wasn't sure if that was right or not, or something in there was wore out. So I decided to retire the old 64 year old pump. I discovered this when I removed it for painting. Minimal end play on the new pump shaft.
Another thing. The 2 zerk fittings. Obviously I'll need to pump some grease in there. How do you know when to stop? I sure as heck don't want any excess grease flinging all over the new paint job.
TIA
Patrick
'49M
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
