Posted by pete 23 on August 09, 2013 at 18:15:43 from (74.47.41.165):
In Reply to: Cranking Oil Pressure posted by PaulW_NJ on August 09, 2013 at 15:33:24:
I would start it and watch for oil at rockers. It won"t hurt a bit to run without any top oil for several minutes. Perfect circle used to recommend blocking the oil flow to head when checking for oil consumption through the valve guides and run it several miles to check it out. If you do not get oil, suspect the center stud for rocker arm shaft as it has a hole drilled part way through and then out the side of stud so if you put in upside down or substitute a different stud you will have no oil to rockers.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
