Posted by Teakettle on August 12, 2013 at 17:19:34 from (74.104.135.107):
In Reply to: 674 IH 540 Shaft posted by nshawkins on August 12, 2013 at 14:57:57:
You have to take off the hydraulic lift cover on top so that you can get at the snap ring that holds the output gear (which won't fit through the hole in the back). The 1000 rpm shaft comes right out the back after you disconnect it from the PTO clutch through the side PTO hole, but the 540 is unfortunately more complicated and needs the top removed. Probably a good idea to get a manual (at least an I&T manual if not an IH one) before digging around in there so you know what to expect.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
