First thing make sure that the TA is actually out on the low side.
If the TA is out on the high side, nothing will happen when you pull the lever, same as if it's out on the low side. It will always be in low.
The difference is, the tractor will want to freewheel when going downhill, with the TA lever ahead. Make sure the brakes work before you try this, and don't have anything hitched to the tractor.
That said, the most common failure is for the low side to go out. Usually this is the ramp and roller assembly inside the TA that's bad.
If you're capable of removing the TA to "take it somewhere" you are capable of fixing it yourself if you'd like. At that point you need to decide if you just want to fix what's wrong, or replace the TA unit completely so you don't have to tear the tractor apart again in 2 weeks to replace some bearing that you didn't notice was bad before.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
