Diagrams are for whimps!!!! Is your distributor properly TIMED to your engine???? Remove the #1 spark plug, turn the engine over (with the distributor cap off), notice what way the rotor is turning, turn motor until the timing marks line up. Now your distributor rotor will be pointing to #1 or #4,with the plug out you should be able to figure if #1 is on compression (rotor pointed to #1) or exhaust (rotor pointed to #4) if you can't put something in the #1 spark plug hole that'll pop out when # 1 is on compression and do it again. Anyway once you have it at #1 top dead center (compression) and you know which way the rotor spins put your #1 wire on the cap where the rotor is pointed, #3 next then #4 and finally #2
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
