Posted by Tom Fleming on August 18, 2013 at 17:16:34 from (67.20.233.75):
In Reply to: Gear Oil in a M posted by F-Dean on August 17, 2013 at 19:08:06:
Well, all the previous answers are fine, but I will add a little detail. Is this a show tractor or are you gonna work it? Show tractor, 80W90 is fine, and is also what I run.
If you are going to work the old girl, next question I have is what is the climate where you are at, and when do you plan to use it the most? Warm climate, hard work (plowing, disking, etc), I would go with the heavier lube.
If you live in MN, WI, SD, ND or similar, and plan to work her in the winter, like snow plowing, I would probably go 80W90 as well. If you live in a warmer climate, go heavier. All the older manuals I have seen offer pretty much what I just told you, except they say to add a little Kerosene in the winter, and then change it out in the spring. Gear lube is too expensive today to operate like that. Plus, today's gear lube has a much longer life.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
