Posted by arkfisher on August 19, 2013 at 19:21:48 from (24.40.234.61):
Well, this thing is coming along... slow as it may be.
I got the tank cleaned out.. there was close to 2 inches of varnish in the bottom. I pressure washed it, then soaked in acetone. After that, it was surprisingly clean... no rust to speak of. I coated it today with RedKote.
While I was working on the tank, it fell from the sawhorses and the fuel return brass T broke off... I've not had any luck finding one, so I'm going to braise the old one back one. I don't think it'll look bad.
I've sand blasted the tank and started filling the pitting on the outside. I'll be sanding and finishing the prep work on it tomorrow.
When I got this thing, I also got 4 boxes full of parts for it which included a total of 3 mags and 3 carbs. The carbs were completely nasty... coats of paint and gunked up like crazy. At first glance, none looked like brass so I didn't worry with it and went on with the carb that was already on the tractor.
WELL... I looked a little closer and noticed that one was brass! I started working on cleaning it up yesterday and finished it today. I even got it put on and adjusted.
Before I swapped the carb out, I had it cranking by hand fairly easy. I had to pull it to get it started this time, and it sounds pretty good to me. The mag is good and hot, and the timing marks are spot on. What can I do to make it easy to crank again???
If you click on this picture, it should play the video.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
