Hi James, Re, injection pump possibly leaking, the seal was about $10.00 but the pump has to be removed and it can be replaced by someone that is good with wrenches but if it is leaking around throttle control lever then requires pump shop attention. To prevent front seal leaking, add Diesel fuel conditioner or a couple of tablespoons of 2 cycle motor oil every time you add Diesel fuel.
Re front end loader, yes it should lift round bales, may have to add weight to rear of tractor if the rear tires are not fluid filled. If the loader has double acting cylinders it should easily lift the front end of tractor of the ground.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
