pete 23 said: (quoted from post at 17:53:02 08/24/13) Once you determine top dead center mark like was told, I can tell you that 22 degrees before top dead center is l 7/16 before that. Fire crater pistons are timed to that mark at full throttle. Some one may have marked off the 40, 30, 25 and 22 or maybe even 16. Hard to tell but they can all be figured out pretty easy with a little math.
Based on Pete's info and with a little backwards math I concluded:
Pulley diameter is roughly 7.49" calculated from backwards math (I do not have precision equipment to actually measure it but that backwards math calculated diameter seems to be rather valid on a quick double check using my eyeballs and a crude tape measure and my standard ole Farmall M as a reference).
22 degrees is 1.438 inches (or roughly 1 7/16") from TDC mark.
30 degrees is 1.960 inches (or roughly 2") from TDC mark.
40 degress is 2.614 inches (or roughly 2 5/8") from TDC mark.
(Note: Use a flexible tape measure and follow the pulley circumference shape to measure the mark from the one you determine is TDC. Knowing which mark is TDC on #1 cylinder is crucial. Even if you have to remove the #1 spark plug and improvise use a common drinking straw and remember to be on compression stroke while an assistant turns the engine over by hand -then you will be able to easily tell which mark is actually TDC).
If you want the formula that I used to figure your own degree setting then use the following formula:
(7.49) x (3.1415) x (your desired degree number) / 360 = the inches from TDC mark
This post was edited by rankrank1 at 12:33:42 08/24/13 11 times.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
