Posted by JimB2 on August 24, 2013 at 17:49:37 from (142.166.175.124):
In Reply to: IH 454 brakes posted by Walter Hardy on August 24, 2013 at 14:19:23:
Hi Walter, Do the leak down test the next morning before you start the engine. Depress each brake pedal individually and see if one or both brakes have leaked down. Check the brake lines that run from brake master cylinders under the transmission cover and under the seat to top of each axle. Check master cylinders for leaks and if no leaks found then most likely the brake wheel cylinder O-rings are leaking.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
