Posted by DeltaRed on August 29, 2013 at 12:03:31 from (97.118.31.225):
In Reply to: 706 injection timing posted by Tom St on August 29, 2013 at 10:07:37:
Inside the 'window are 2 'disks'.Each has a mark on it.One 'disk' is stationary,the other rotates.When both marks are lined up,you are at TC.-Provided you have the flywheel marks in the correct place.As was said,the little lens just lets you watch the advance movement as the engine is running.The way I do it:Set the flywheel X degrees(acording to the book) BTDC.At my altitude (5000 ft)advance 2 MORE degrees.Install pump with both marks lined up.You are ready to start....
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
