Posted by davset on September 01, 2013 at 10:25:53 from (24.177.226.188):
In Reply to: Super A axle pivot shaft posted by Charles Green on September 01, 2013 at 09:01:14:
Did you replace the pivot pin, or is it original? It should have a notch ground in both ends of the pin to allow the clamp bolts to pass through the clamp holes AND lock the pin in place. Knock the pin back out about an inch or so and you'll see one notch. Rotate the pin till the notch is on the bottom, then you can reassemble and the bolts should go through.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
