Re: ongoing battery saga
Posted by ltf in nc on November 30, 2000 at 16:18:20 from (206.228.214.72):
In Reply to: ongoing battery saga posted by joe on November 30, 2000 at 12:03:51:
Definitely it could be the battery. To isolate the problem from the battery, first charge the battery and then disconnect the battery. After the usual time has lapsed for it to discharge, reconnect the battery and attempt to start the tractor. If it starts, the problem is not the battery. However, it sounds as if there is a drain on the battery. This drain could come from numerous sources such as defective wiring insulation, bad regulator, incorrect wiring, faulty switch, etc. If you have a digital volt ohm meter you could check for a small current drain. Without a meter sometimes a small 12 volt panel bulb can be placed between a battery cable and its corresponding battery post. If there is any glow with the switch off then there is a drain that should not exist. I read that you are using a generator. Your problem is not nearly as prevelant with a generator as it is with an alternator. With an alternator the drain is typically through the regulator built in the alternator. Hope this helps.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
