Posted by The tractor vet on September 02, 2013 at 20:50:37 from (76.212.228.18):
In Reply to: 1066 PTO problem posted by NHBalerman on September 02, 2013 at 19:38:54:
NO it is NOT the pin . If the tiny pin is sheared then you will not have a PTO . (1) when does it quit working ?? when going down hill ??? add more hyd fluid . (2) does it slip under load ??? If it has slipped under load then there is a good chance that it needs rebuilt and you don't stop at the clutches ya need to check the housing where the clutch drum runs in and ya look for ware where the teflon seal rings ride . (3) ya need a special fitting and a gauge that will read 600 PSI to check clutch lock up pressure and Lock up pressure MUST BE CHECKED with the Hyd oil AT WORKING TEMP. And the gauge should read for a 1066 245-265 PSI .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
