Posted by Janicholson on September 04, 2013 at 16:13:05 from (74.60.94.18):
In Reply to: thoughts and ideas posted by Ed in Pa on September 04, 2013 at 15:50:57:
Put 8000ft (High Altitude) pistons in it, with the thin sleeves to give it a bigger bore. Use a 350 intake and carb, and a 350 cam . Run the timing ahead to 30 degrees total or find the sweet spot on a dyno.(use 93octane fuel) Remove the belly pump, belt pulley, and PTO. Use a small 12 v battery and no generator (constant loss, just keep it charged) remove the air cleaner and use a paper filter on the carb intake. Make a hitch to replace the U and drawbar. Put on brackets to allow hanging weights on it to make weight classes. These modifications (and no filled tires can put it is a lower weight class) Be sure to follow the rules. Good luck, Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
