Posted by Rich'sToys on September 15, 2013 at 15:22:28 from (74.44.48.98):
In Reply to: belt pulley control posted by Mitch E. on September 15, 2013 at 09:02:55:
As mentioned above, the radiator shutter is a set of louvers in front of the radiator which can be opened or closed in order to regulate the operating temperature of the engine. In the old days, these engines would be run on distillate and needed to be run at a warmer temperature-hence, you closed the shutter as required. No one uses distillate any more. Everyone uses gasoline. So the shutter should be left wide open, or the engine could overheat.
Regarding the fan, it is driven by a belt running from the crankshaft of the engine. Therefore it will turn whenever the engine is running. It is supposed to do that. If it doesn't, again the engine will overheat.
Hope this helps. As also mentioned above, get an operators manual for your tractor and study it over carefully.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
