Re: trouble with 574 international tractor
Posted by Janicholson on September 17, 2013 at 16:27:23 from (199.17.6.25):
In Reply to: trouble with 574 international tractor posted by c4thisguy on September 15, 2013 at 15:48:48:
The firing order is 1342 from the front of the engine. Take out #1 plug, put your thumb in the spark plug hole (or hold a tapered cork in the hole gently) then rotate the engine in short bumps (coil wire grounded to avoid unpleasant shocks). When the air is pushing out of the hole, it is on compression stroke. a little further turning with the fan, or pushing it in high gear will allow you to get to TDC, or very close. (put a straw in the Spark plug hole to see the piston move up as you push the tractor.
Remove the dist cap and that is #1 from there (in the direction of rotation (Clock wise) it is 3 then four then 2. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
