Like others have siad , might be restricked fuel flow , But have you checked the manifold bolts to see if they are tight ?? , have you checked the heat riser to make sure that it is working ???, When was the last time you did a complet tune up and checked ing. timing ???, when was the last time you set the valves??, are you running 93 octane grade gas??? This is a modern 6 cylinder gas engine and it is a high RPM engine and requires the 93 octane Read in the org. operators manual on MIM, fuel requirement check ing. timing at full throttle for full advance . run only a C86 A/C spark plug or a 3116 Autolite. for plugs. There is no adjustment for fuel on the carb as when the key os turned on the solenoid should pull the pintel wide open off the main fuel jet . NOW if there is junk and grud in the carb then you may have a small problem .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
