The UB220 is the industrial version of the BD-220 six used in the trucks from the early '50's. Yes, the C-221 is derived from the same BASIC design.
That said, the BD [Black Diamond] engines came in a straight-valve configuration [early engines], and a tilt-valve [later engines]. The tilt valve has a wider valve cover. On the truck engines, if you put the pistons from a tilt-valve engine into an engine with a straight-valve head, you end up with around 13:1 compression...and usually major overheating, until you figure out what you did.
"Better" is a relative term. IH went to the tilt-valve engine because the straight-valve engines developed a reputation for hanging exhaust valves open, after which the piston would lop the head off the exhaust valve, with a bit of noise and a distinct loss of power. Tilt-valve engines weren't known for having this problem.
Others may know better about the bellhousing patterns. I'd wager they'd be pretty close...but I've been wrong before.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
