Posted by JimB2 on September 24, 2013 at 17:56:59 from (99.241.76.141):
In Reply to: Instruments on IH-784 posted by jp2code on September 24, 2013 at 10:26:26:
Hi, Wiring diagram can be found at: http://cngco.com/wiring_diagrams/IH%2054-74-84%20SERIES.pdf
Re fuel gauge, I believe that the fuel gaug showing full is that there is a short to ground in the wiring harness. The wiring harness goes from under the dash on top of the transmission under the sheet metal cover, under the seat to a molex connector behind the seat and then to rear lights and fuel tank. There is one ground wire that is connected to a bolt at behind the seat on deck plate. Re hour meter, does the Tachometer work? If no then drive cable or drive gear on front of engine. If yes then have to send hour/tach for repair. Re temp gauge, could be coolant sensor that is located in coolant manifold by the thermostat. Could also be a wiring issue.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
