Re: Mowing speeds
Posted by Bill {Antique Acres} on December 03, 2000 at 06:36:07 from (63.162.254.39):
In Reply to: Mowing speeds posted by Bill Jolley on December 03, 2000 at 05:45:32:
You cannot adjust the governor to speed up the mower. The governor is designed to keep the engine running at a steady speed wherever you have the throttle set. The only way to speed up the mower is to open up the throttle. On a Cub you might as well forget about mowing in 3rd geard. That is road gear to a Cub and it does not have enought power to mow and pull itself. It was not designed to mow in that gear. As for the mower turning too fast, you can never have it turn too fast. The faster it turns the better vacuum you get, hence the better cut. A Cub's PTO is designed to run directly off the crank. That is why it turns faster than a normal 540 pto and in the opposite direction. I know with my Cub, if I keep my yard cut regularly then I can mow in 2nd, if not then it's first. I would consider yourself doing well if you can mow in 2nd all the time. Of course a flat yard helps. I hope this has answered your question. Bill {Antique Acres}
Post A Followup
: Re: Re: Mowing speeds
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
