Posted by jiminy on September 26, 2013 at 04:47:17 from (216.227.61.96):
In Reply to: ihc 3688 hydrualics posted by Andy Kitching on September 24, 2013 at 18:56:27:
I have one of these and have experienced about every problem one can have with it..first the hitch pump is located down behind the rear tire on the clutch side..valves are on the oppisite side. the o ring mentioned sounds as if it could be your problem if things went away gradually. it is located in the pump mounting plate to remove you must drain all hyd oil and remove plate..pump will come with it..pump can be inspected when you do this..when the pump shaft breaks its usually still on pump but you can turn it easily..if its good it should be difficult to turn. post back and let us know what you find.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
