Posted by pete 23 on September 26, 2013 at 10:19:03 from (74.33.77.105):
In Reply to: 560 hydraulic lever posted by Dirt on September 26, 2013 at 08:21:08:
Moving lever to the rear should raise the hitch on a 560. The normal mix up on these is that the previous tractors like a 450 were the opposite. However,the 450 did not use teledepth valve with follow up linkage. Now if someone has removed the teledepth valve and linkages and installed a regular valve , you could reverse the hoses and get by. If it still has teledepth with linkage to hitch, reversing the hoses will damage parts, most likely the differential gears in the valve,and of course it will not work.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
