Posted by Tom Fleming on October 02, 2013 at 04:28:07 from (67.20.233.75):
In Reply to: F20 coolant leak posted by doehmke on October 01, 2013 at 19:31:42:
Not a problem. The F-series does not seal everything up tight like 36F30 says. They will seep a little around seals and that is a fact of life. However, the head bolts, manifold bolts, oil pan bolts, some of the transmission bolt are open to the fluid chambers (oil pan, cooling jacket, transmission, etc.) these bolts/studs all should get a dab of your sealant of choice. I like permatex, however, use what YOU like and have good experience with. None of these are high pressure, so like the old TV commercial, " a little dab will do ya".
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
