I did my SA awhile back and this is how to do it in a press. Put a bearing separator, some call it a bearing puller, between the gear and the bearing. Support the bearing separator in the press with the long end of the shaft hanging down. Press off the gear making sure not to loose the woodruff key. When pressing the new gear back on, pay careful attention to get it seated just like the old one so the shims on the belt pulley drive still give the right adjustment. When you get it all back together, remove the pipe plug on the belt pulley housing on the top right and inspect the clearance. The two bevel gears should not be bound up or tight nor too loose. While looking in the hole rock the belt pto shaft back and forth and make sure there is a little slop. If you press the gear back to it's original placement on the shaft and use the same shims, it should be ok. While your at it, it's a good time to check the bearing #25 and replace it if worn.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
